Water On passanger side floor, leaky winsheld or what?? Heater core is good.
einstein
Active member
bountiful utah
Just was cleaning my car and noticed water was on the passenger floor pulled up part of the carpet and its pretty wet, its been raining here alot, is this caused by a leaky winshield or what would cause it? I know its not the heater core at all. Seems to retain water when its parked outside and raining, any help or suggestions would help great.
I need to get this fixed so it doesnt start to rust all out.
THanks
Matt
AuSpecVr4
Brisbane, QLD
I have the same problem, check under the windscreen lining that runs over it into the guard, mines old and bent out of shape so you can see the rust forming on the seam to the firewall. Sadly this has happened on both my sides but passenger is worse. The water leaks down the firewall behind the carpet and suddenly you have a swimming pool in the front of your car /ubbthreads/images/graemlins/bawling.gif
BoostedAWD91
Danville,Pa
Best way to find out how bad it leaks and where is lay in the car where you think its coming in and have someone else pour water over the car till u find the leak. Then you can go from there on fixing it
misterfixit
Midlands, UK
probably weeping into the a pillar box section. top of the cowl is the main rain run channel. pop the gaurd off and get some better pictures of the base of the screen pillar.
Once you've got the fender off you can look in the spout to the inside of the cowl top (which is used as a gutter) and see if that has been breached. Any water in tat area will come down the inside of the firewall.
That looks like its going to need some welding right there.
One real good course of action is to pull the sound wadding/dash/heater box out then do as above.
Rich
AuSpecVr4
Brisbane, QLD
Yes all in good time i will, but with the summer weather in AUS we get crap loads of rain so i used silicone to cover it up for the meantime /ubbthreads/images/graemlins/frown.gif yea i know, naughty. But planning to get it done properly next year when i have the time to pull guards off and rust convert/grind/weld new panels to make it water sealed.
