TT CTS-V goes down to my stock motor hx40 car
Interesting. I'm curious to see how long the gears take the abuse. If they hold up, that's a hell of an alternative to the traditional dog box, and A LOT cheaper. It definitely doesn't look like you're having a problem rowing the car through the gears from the vids you posted. What first gear and diff are you running?
blackvr4
NJ
Quoting ApexHunter:
That's cool. Similar concept to a quick shifter on a bike, where you have the torque sensor on the shift rod that sends a signal to temporarily cut spark when it senses the movement on the shifter. Would be sweet to move the sensor from your clutch to your shifter so that you don't even have to tap the clutch. Your setup now works fine, but this would be badass, just sayin. /ubbthreads/images/graemlins/devil.gif
Sweet car BTW.
Now that is an interesting idea....not sure how i could make that work but it would def be possible. It just one pin on ecu that needs to see a ground. And it activates it.
As far as the gears lasting i had everything shotpeened and have the trans shimmed super tight. Everything is preloaded. Wont last forever its still a factory gear. 1st gear is a dsm gear and the rear is a 1g 4bolt really nothing fancy with the car, typical "DSM" mods lol
blackvr4
NJ
Also if you guys wanna see a good non cell phone video of this run follow this link.
Launch
Texas
You sir are an inspiring soul! Cheers to happy hunting and v8 killing /ubbthreads/images/graemlins/smile.gif
Finally somebody got that V, glad it was you. I help spread the word all over FB when I first saw it. Good job.
