The ole 4 bolt
What car does it come from? Thats why I'm a newbie. Tryin to learn as much as I can about these cars..
Thanks
Tony
Jesh
Soldotna, Alaska
The 4 bolt rear diff comes out of 90'-94' TEL (talon, eclipse, laser). At least the ones that came stock with awd.
toybreaker
iconoclast
The 90 to 92 (and a half) model year t/e/l cars had three bolt rear ends.
They may or may not be equipped with a lsd viscous coupler.
The 92 and a half to 94 t/e/l cars were equipped with four bolt lsd's.
toybreaker
iconoclast
No worries!
The interchange is a little weird.
The important thing is that you know what you;re buying, and why.
Some folks just want the lsd for loose surfaces/snow use
... and some folks make so much power they break things ...
Those folks are best served upgrading to the four bolt units, as they have upgraded c.v's/axles.
gtluke
dirty jersey
You can save on shipping if you just buy the axles and the carrier. The case and ring/pinion are the same.
Don't forget the axle cups that mount to the hubs.
