What size of bolt to remove the front axle nut?
711 Active member Joined Apr 10, 2014 Messages 25 Location Neverland May 30, 2014 #1 What size of bolt to remove the front axle nut?
711 Active member Joined Apr 10, 2014 Messages 25 Location Neverland May 30, 2014 #2 Did a search. 32? Anyone can confirm?
fuel Well-known member Joined Feb 23, 2009 Messages 2,166 Location Toronto, ON, Canada May 30, 2014 #3 yes 32mm from memory.
mitsuturbo Well-known member Joined Jun 2, 2008 Messages 3,551 Location Near Seattle, Washington May 30, 2014 #4 Definitely 32mm. Rear spindle for 4 bolt swap is 27mm Transmission shaft end nuts are 36mm Those are the only ones on the car i can think of that are larger than 21mm.
711 Active member Joined Apr 10, 2014 Messages 25 Location Neverland May 30, 2014 #5 Thanks fuel and mitsuturbo.
