If I replace the rear calipers only, do I need to bleed all 4 calipers or just the rears?
stealthtt24 Well-known member Joined May 24, 2005 Messages 2,746 Location Orlando, FL Sep 13, 2012 #1 If I replace the rear calipers only, do I need to bleed all 4 calipers or just the rears?
Tre3zy Well-known member Joined Nov 25, 2008 Messages 602 Location South San Francisco, CA Sep 13, 2012 #2 might as well bleed all of them... make sure you do it from the farthest to the closest
turbowop Well-known member Joined Apr 29, 2001 Messages 11,982 Location Yakima, WA Sep 13, 2012 #3 As long as you didn't lose much fluid during the swap, you can just bleed the ones you replaced.
stealthtt24 Well-known member Joined May 24, 2005 Messages 2,746 Location Orlando, FL Sep 13, 2012 #4 Awesome thanks guys.
