Stock radio
G
zompton
Does anyone know if the stock radio with the cd/ aux input on the front needs the amp in the trunk to work?
maroonmetallic
central WI
I feel like such a newb for not knowing about an amp in the trunk.
But I do know I used the factory CD player in: 92 Galant LS, 93 Galant LS & 92 GSR.
I didn't touch any kind of amp in any of those cars.
And Id like to say the 92 LS didn't have one.
-Shawn
G
zompton
This is the one I would like to purchase:
The seller states his car did not have an amp, but my stock stereo setup does. I have the one with the cd player instead of eq.
G
zompton
Does anyone know what the 6 pin plug on the right is for? Is that the amp?
JNR
ca
While I have that same oem stereo, it was never hooked up when I bought the car (aftermarket system), so couldn't say if or what the factory amp setup is/was, but being you have the CD setup, have you looked at the back or what harnesses are there on yours? I would *think* any of the VR-4's have pretty much the same wiring regardless of what stereo they came with, but could be mistaken.
Are you looking to stay all oem, or have you thought about running an aftermarket amp with a converter (to run RCA's off speaker outputs)? The biggest challenge to that though is if you don't have one of those auto on amps (that come on with either the hi or low input signal) then finding a 12V remote source can be challenging. Least that's how it was in my last jeep WK, as it was all 6V signals...Ended up just making a switch to do it manually. Running an older punch 150 that required a remote.
But wait a second, these had power antennas, so that probably wouldn't be hard them to just tap off that line.
bobdole
U.K.
How many different stock head unit's where there. I remember my first vr4 had CD player w/EQ and amp in the trunk.
the 91 stock head unit requires the amp in the trunk or you have no speakers. I once tried to get mine working, but gave up as three amps I acquired were all water damaged and did not work in at least one channel. I put in a radio from a 99 Galant and it works without the amp.
The radio you show should work without the amp. I think the 91 setup uses a DIN cable for the amp (not 100% positive on that anymore though...).
gvr4ever
central Indiana
My 92 came with a tape deck only. No EQ, CD input, no amp in the trunk.
I think it would be worth the effort to just get new gear at this point. It isn't that hard to install and you can choose exactly what you get instead of relying on old gear that can break at any time.
PJGross
Lake Orion, MI
Where is the amp in the trunk?
My '92 had the double din CD player. When I got it in '98, it had AGXs and HRs and the CD player skipped quite a bit, so I put in a Kenwood about 15 years ago. I still have the stock combo, but I never looked in the trunk for an amp? Glad I kept it, I guess, some new owner could put back to stock. Still have stock struts, too. Never got around to pitching them.
Hopefully I can resurrect #490 from its 13 yr hibernation over the winter. Seeing those new calipers in the other post reminded me that I have new rear calipers just sitting waiting to go in as well.
-PJ
