steering issues
Epifool
greencastle, In
Fellas, im havin a litle trouble figurin out whats up with 1848. The alignment seems off, it wants to jerk right n left over bumps, plus it looks like the front tires may be out at the top, (-camber?) Any insight? Anybody?
transparentdsm
Cherry Hill, NJ
shot bushing in the front suspension? a arms, tie rod ends. an endlink could have broke.
have you looked under the car ?
IncorpoRatedX
Arizona
is the AWS eliminated and rack removed? back end will follow the road if so and will cause this sort of behavior.
if not, agreed, check bushings ball joints etc
Epifool
greencastle, In
Aws is gone, its never had any trouble before. I'll thoroughly check bushings, and tightness everywhere else, as i did just get her back together after the trans replacement
