small 16g leaking ???
uncleben4rice
antioch ca,
Put my car on the rack to change over to redline MT90.. Compressor told me my 16g may be my problem.. we spotted a lot of exhaust resin on the bottom of the turbo.. is this a sign that the turbo is bad or needs a gasket???
while it's on the rack (or jackstands) run the car and put ur hand close, w/o losing any fingures. If the gasket is bad, you will feel the pressure leaking through and smell the exhaust
cOmpressor
Bay Area, CA
Hopefully we can work this thing out on Sunday. Even with no turbo you should be running faster that the what you are.
