Shimming lifters
Spyder
Des Moines, Iowa
Was there a thread in this section on shimming lifters?
I was wondering if I needed to do it to my engine as I have beehive springs and retainers installed.
BogusSVO
Pensacola, Florida
Why do you think you need to shim your HLA's?
Correct, the only time you really need to shim the HLA is with a reground cam, or when a shop really flubbed the valve job and set tip height waaaaaaay to short.
Beehive springs have no input to having to shim the HLA.
ktmrider
Tempe, AZ
^^ Most likely they suggested you "shim" the aftermarket valve springs ( Install Height, Seat Pressure, Spring Bind at Max Lift ).
Spyder
Des Moines, Iowa
Used beehives out of an evo. I had them measured at my machine shop and they were well with in spec. at installed height.
FlyingEagle
THE Ottawa
As a side note but still on topic, what type of shim should be used?
I just sent a set of regrinds (HKS264 profiles) and would like to know what is best to recommend to him. Previously, it appeared that non-hardened washers were used, the type from the hardware store. Not sure about the properties of the coating but they looked like plain stamped steel. What height is recommended?
BogusSVO
Pensacola, Florida
The shims used under HLA for regrind cams is just a run of the mill #6 flat washer, appox .040 thick.
The shims used under valve springs are made by VSI (Valve Spring Insert) and come in .015, .030 and .060
bigblock4g63
new jersey
I have used these in the past.
Maybe SVO can post what part numbers he uses. I will look for the numbers I used from GOODSON
BogusSVO
Pensacola, Florida
Bad thing about VSI is they package for builders, so each box is a lot of 100, (50 for the HP)
The Tomi are just expensive, really? $11 bux for a 8pk??
The VSI run about .75 per shim
