Shifter play.
AuSpecVr4
Brisbane, QLD
Hey
I have an issue with my shifter assembly. it its worn out on the lower arm and rocks up and down which is really ruining my shifting. What can i do? is there an aftermarket bushing kit i can use to space it up and make it tight again?
Dark_Horse
Morrison, CO
Does the whole base move up/down when you shift, or is it just the shift lever that has extra play?
If it's the base that's moving, the Symborski shift kit replaces those rubber bushings in the plate with metal ones. It eliminates any slop in the base and gives a really firm shift.
AuSpecVr4
Brisbane, QLD
The bottom shift lever, it moves around at least 10-15 mm after I used some washers underneath it, and before it had around 30mm of movement. The base is fine, that's definetly not the problem.
