Ryan 107/1000
Just some pics i took of my galant i just purchased from shane. 107/1000
Cold out so pics where quick , car is dirty as well sorry...
Tell me what you think good and bad.... :)
The Mods
· Evo III Big 16 Turbo
· Evo III Manifold and O2 housing
· Evo VIII Injectors
255 fuel pump
· Rebuilt Head new gaskets studs etc.
· Valve job new guides pressure test & resurface
· New Non-Ticking lifters
· New plugs and wires
· 2nd Gen Mas air and intake K&N filter
· Hard pipes and Front mount Intercooler
· Powder coated Valve Cover
· SS Brake lines
· Cross drilled Rotors all 4 corners
· 3 in. Turbo back with high flow Cat.
· Rebuilt Trans and syncros
· Spec Clutch Fadanza Flywheel
· SS Clutch cable
· Shifter bushings
· TEL shifter with Evo shift knob
· Rebuilt Transfer case
· New Slave and Master Cylinder
· Battery Relocated to trunk
· Hyper Ground kit
· HKS BOV
· Turbosmart in cabin boost controller
· Apexi turbo timer
· Apexi AFC
· Eprom ECU with Key Diver Chip
· KYB Shocks with H&R springs
· Tien camber plates
· 17in Konig Helium Wheels and the stock wheels
· Whiteline Sway bars front and rear
· New front axle
· Front and rear strut tower bars
· Boost gauge in dash and Mitsu. Gauge kit
· 93 Head lights
· Clear corner lights
· MMC badge
· Tinted windows
· Evo IX steering Wheel
· Euro Grill with driving lights
· No AC I had it removed
