Rear rotor options? Side door decals?
RHDgalantVR4
Calgary Alberta
Sory if these 2 questions have been answered cant seem to find using serch. I have power slot on the front but cant find anything other then stock replacement for the rear. Anyone know where to find the decals that are sapposed to be on the rear doors?
You should be able to find rear powerslots online somewhere. If you can't, buy regular rotors and take them to a machine shop and have them put slots in them.
LIV4PSI
O-H-I-O
PM Gabor for the decals
mitsuturbo
Near Seattle, Washington
I just want to add... For the love of tits, please don't have your rotors DRILLED, and don't buy cheap drilled rotors if you may have been considering it, or could find them. If you're driving the car hard enough to need slotted rotors in the REAR, then they'll definitely end up cracking if you don't go with a quality rotor, especially if they're "cross drilled". I wouldn't worry too much about a slotted rotor cracking, but every set of cheap cross-drilled rotors i've seen (with or without "slots") has cracked inside of 18 months.
RHDgalantVR4
Calgary Alberta
Quoting LIV4PSI:
PM'd and payment sent /ubbthreads/images/graemlins/smile.gif
