"Tein Spirit"
number3
KoP, PA
Well I drove number3 today for some break in miles and the car seems to handle pretty well, so far as I can tell.
The rear top nuts on the Teins keep coming loose. I think I have a fix though. I need to soften them up (currently on #8) the car bounces real hard over bumps. They are much stiffer than the AGX/H&R combo.
Harry
number3
KoP, PA
I just had my car weighed and corner weighed.
number3 weighs 3278 lbs.
945 LF 915 RF
721 LR 697 RR
No gas to speak of in the tank w/o driver.
I still have rear bumper, AC and power steering.
Battery in the rear of the car. No power seat belts. Stock seats. Wheels and tires are roughly the same as stock (with in a few pounds)
Cage, FMIC, turbo, and WG are the major weight add ons that I can think of.
...with a someone about 20lbs heavier than me in the driver seat and still very little gas.
1038 937
797 732
Tint on the windows is about all I have left to do to the car.
4orced4door
Raleigh, NC
Must be nice!
Must be nice!
Well when you put as much time and money into your car as #3 then even the tint is a last item
. BTW Harry what alignment settings did you get for your Tein?
number3
KoP, PA
LF
Camber -.03
caster 3.26
toe .07
RF
Camber -.33
caster 3.32
toe .06
FRONT
cross camber .29
cross caster -.07
total toe .13
wheel base difference .07
track width diff -.42
track width 60.5"
ride highth 13.64"
LR
camber -1.12
toe .42
RR
camber -.68
toe .42
REAR
Total toe .82
thrust angle .00
set back .14
axle offset .00
track width 59.7"
ride height 13.24"
They are much stiff than the AGX/H&R combo.
Wow i couldnt even imagine that.....and i only have these agx's on setting 5
turboflanagan
Peachtree Corners, Georgia, USA
Oh yeah! I put mine on in my driveway and they were on full stiff. I just pulled it out of the driveway and it felt like I just installed a steel rod with a decrative spring design around it. Even the crack between concrete sections was really rough.
turboflanagan
The rear top nuts on the Teins keep coming loose. You mean the ones inside the trunk on top of the strut tower?
Harry
Mine seemed to soften up a bit after a few miles. I usually ride around town with mine on 8-10 front and about 4-5 rear. I don't have any other suspension mods like sway bars or strut bars.
I never did have it aligned because I had Really crappy tires on it, but that will need to change in the next couple of weeks.
number3
KoP, PA
Yeah, the one on the very top, the next thing in line after the dial/knob that adjust the ride.
Harry
Just an FYI to you guys. If there is a place local to you that can corner weight your car and align it do it. BUT you must be done modifying your car as if you do anything that can upset the weight balance (like moving the battery to the rear, removing the bumper beams, etc) you throw off the balance. With coilovers it will make a world of difference between non-weighted and weighted cars.
Rich
number3
KoP, PA
Car rides real nice with the front at 8 and the rear at 10. Still may need some tweeking (still alittle bouncey) but so far so very good.
Double nutting the rear nuts on top seem to have fixed the problem of them loosening up.
Harry
Nate
Worcester, Pa
That's surprising that the passenger's side of the front of the car is only 30lbs lighter than the side that has the engine on it. I didn't think those scattershields weighed THAT much. ;-)
number3
KoP, PA
They (SSSS) only weight 7lbs
Maybe that is why Mitsu but the battery over there...
number3
KoP, PA
I currently have the fronts and rears now at level 8 and the car handles the bumps much nicer but still has a killer feel. The tire psi is 34 front 32 rear.
The turn in and feel the car has now is incredible.
The car does seem to push though.
Only 200 miles or so and I can open her up!
those look gorgeous, ive got a friend that has a wholesale account with them, might have to go with that over the agx/pro kit setup
