4doorboost
so m car is running really weird. i am getting cut, stumbling at part throlttle pretty bad. at full throttle my car runs better and and very low throttle. my afr is also reading lean sometimes, like 16+ when im cruisin nd occasionaly will just sit at 21. im gunna check for leaks but its having weird syptoms for leaks. im thinking it could be the tps sensor is not calibrated correct. any suggestions or easy ways to calibrate it? any suggestions on getting to that lower screw or if something else may be the problem. thanks
bryce ocain
bryce ocain
