Power door locks?
dsm10o0
San Jose CA
Do these cars come with power door locks? My car only opens 1 door at a time using a key and ive seen someones elses car open all at once with a key.
These car have manual power door locks either front locks will lock/unlock all doors engine running or not back doors are on their own lol..
yeti
san diego california
Quoting yeti:
Mine unlocks or locks all doors when the engine is running only
thats shotty wiring then correct?
dsm10o0
San Jose CA
What could cause mine to not unlock all at the same time? Ive check all fuses and changed the busted ones but its still nothing.
Adorsey
mass
Do some searching, try searching for +ETACS, or +doorlocks, +electrical.
I haven't had door locks, heat, working windows, working sunroof, heat, working interior lights, radio, heat, radio intena, speakers, in probably a month. And its getting colder by the minute here.
Weird thing is, I will do a real hard launch, or like nls to third, and everything will just start working, and then go away the next time I rip on it, or shut my car off.
rost
tarzana,ca
Adorsey,could your problem be 100amp fusible link related?When my alternator went out,it burned 100amp fusible link and it took all the good stuff with it(windows,heat,a/c,etc.)
Replaced the alternator and the fuse,and all back to normal.
Adorsey
mass
hmm. I had replaced the 100amp fuse. Maybe its not in correct... Just made a very sturdy battery tray. Ill have to look into that.
Alternator should be good.
Fuse blu when I pulled the passenger seat out to vacuum, and the amp the previous owner installed grounded out. wicked sketchy.
