Oil
Steve885
Concord ca
I used vr1 20 -50. "Race engine oil " this time...really happy with it...it seemed to keep the car about 10 degrees cooler .even after doing a bunch of pulls..
/ubbthreads/images/graemlins/confused.gif Your coolant temps stayed 10 degrees cooler, or you mean your oil temps?
Coolant temps won't be changed by using different oil. Oil has no bearing on the thermostat, which is what regulates the coolant temp. Unless your cooling system isn't up to par...
