OEM Part # Request (not found in Info)
maroonmetallic
central WI
Looking to see if anyone knows the p/n for the t-case breather (vent).
Also looking for the b-shaft bearing p/n for the oil pump driven shaft.
Thanks.
-Shawn
fuel
Toronto, ON, Canada
MD727784 is the breather. MD040598 is for the STD sized oil pump driven balance shaft bearing.
Shawn, you mean that little rubber bulb for the breather? I can send you one with the connector.
