Would depend on if you are running a stock ride height? You will also loose some some low end grunt, but gain top end. If your running stock suspension should be fine. Most of us are running a 2-3" drop and don't have any tire rubbing issues on the wheel wells. You might hit on the inner frame rails however!!!
