New to the forum? Introduce yourself here.
The Netherlands
Aye, Randy is my Name.. and im new to the 6th gen game. (Based in the Netherlands) Not a newbie on the overall Galant platform (8g). Had a few Legnums and was the face behind Pandaparts (international 8g parts guy) for 8 years. And since 2.5 years now in have a 6g GTI with a 4g63T 6bolt swap in it. Imported from the promised land. Its a bit of a fixer upper (what i wanted) so that i dont get bored.
nazagalant1993
buenos aires , argentina
Welcome to the forum, Randy.
Good to have you here. That 6g GTI with the 4g63T swap sounds like a solid project to keep you busy. Is the engine currently stock, and what are your future plans for it?
Feel free to share some pictures whenever you start a build thread. Enjoy the community.
The Netherlands
Thanks for having me,
The Galant has the following:
1989 4G63T 6Bolt
MD150427 ecu
TD05 Turbo
5speed manual, (originally AWD box, but modified for FWD)
Full stainless exhaust with HKS hiPower silent endbox
Uprated fuel pump
GTO brake calipers on the front
Big front grooved and drilled discs
Central locking
Powersteering
Airconditioning
Electric Windows
Roofwindow
Aftermarket steeringwheel and hub
VR4 clocks with the digital boostgauge and 2 light mode option
Grey Mitsubishi Lancer Evo 3 Recaro seats
On modified Galant 8th gen recaro seatrails
VR4 RS hood
Hoodbra
Aluminium radiator
Custom intercooler
Hurricane chargepipe
GReddy bov
Seethrough timingbelt cover
Front and rear strutbrace
Needs a few minor bits doing
paintwork is not the best
Needs a good tune
Came with
Spare gearbox
Stock shocks and springs
Extra coilovers
Currently in the corner of my shop since shes throwing tantrums. (Throttle body boostleak, maf sensor dead) looking for a good alternative for the oldscool maf (e5t02671) like changing it to a evo 3 one or something like that. But as i said.. new to this platform so need to learn a lot haha.
yubh8tn
coeur d alene, idaho
1989 4G63T 6Bolt
MD150427 ecu
TD05 Turbo
Uprated fuel pump
Central locking
Powersteering
Airconditioning
Electric Windows
Roofwindow
VR4 RS hood
Hoodbra
Aluminium radiator
Custom intercooler
GReddy bov
Needs a good tune
Came with
Spare gearbox
Extra coilovers
The #482 maf and #399 mafs are great options. 482 is found on Monteros and 399 on Evo 8/9
yubh8tn
I have some 482 mafs on the shelf, since the 8g galant uses them for the 2.0 sohc 4g63, i was thinking more of the #609 since my buddy uses that one on his evo 3
482 and 399 can flow more than 609 (y)
Yes the 482 and 399 are significantly better than the 609. I still have enough pieces to make a few more adapter harnesses if you want one to convert as plug and play (still need fuel control like ECM link).
ZeroMelody_
New member
Nebraska United states
Hi I'm Mark. I'm 20, from Nebraska, I just got my first GVR4 (327/2000)
Its 4G63 has been built+rebuilt and currently has an HX40. Chassis has 200kmi. The underside is plagued with surface rust but soon it'll be freshly repainted and rust free. I'll log all changes and events with this galant here.
ZeroMelody_
New member
1989 4G63T 6Bolt
MD150427 ecu
TD05 Turbo
Uprated fuel pump
Central locking
Powersteering
Airconditioning
Electric Windows
Roofwindow
VR4 RS hood
Hoodbra
Aluminium radiator
Custom intercooler
GReddy bov
Needs a good tune
Came with
Spare gearbox
Extra coilovers
Where'd you get that spark cover?! Asking for a friend.
shadowdweller
Member
Green cove springs
Owner of #1611 91 gvr4 2.3 stroker. (Full build list at bottom)
I owned multiple 1g talons in the late 90s, early 2000s. Sold my 91 talon tsi AWD about 18ish years ago, and had regretted it ever since. Last November I was in the market for another one.
Came across a 91 galant vr4 with a lot of upgrades for a a decent price considering the upgrades($12000). Got it home and started having oil pressure issues. So, took it in to have it diagnosed.
Ended up being a bent crank that was eating away at the bearings. So opted for a full rebuild to fix any potential issues.
While it was full of high end parts, it looked to have been thrown together, and ran hard.
I strategically upgraded everything that I could afford to upgrade. Toward the end of getting all the parts and the engine work done, I decided that I might as well upgrade the transmission while it was out. That was a process in itself because i got a neat evo 5th gear for better fuel economy on the highwaysince this would be my daily. Come to find out someone changed the 5th gear at some point to and 1990 gear assembly which didn't work with 91-94. Parts were very difficult to find and it ended up being the same price for me to just buy a used transmission and transfer case and swap the parts.
Everything is being put back together as we speak and hopefully will be sent to be tuned within a few weeks.
It's been a long year of waiting and I'm ready to see what she can do
Build:
Stroker 2.3 - 6 bolt 4G63
- manley pistons 9:0:1 / Eagle rods / Race bearings
- bored .45 over
- Cometic head gasket
- ARP Head studs
- Brian Crower Springs and retainers
- eagle forged crank 100mm 6 bolt
- HKS 272 cams
- Straight Cut Oil Pump Drive Gear
- hks fine tune kevlar timing belt
- aisin Water pump
- Custom welded aluminum Intake Manifold
- 70mm S90 Throttle Body
- Magnus IAC remote mount adapter.
- Torque Solutions Thermal Intake manifold gasket
- AEM cams sprokets (black) with ARP bolts
- Kiggly HLA pressure regulator
- ATI super damper harmonic balancer
- Thundervolt 10.44mm spark plugs wires
- Jay racing alternator relocation kit with steel bracket
- Powder coat valve cover (wet black)
- Fluidyne Dual pass radiator with custom bracket
- 16" & 13" Spal fans
- 165 thermostat
Turbo & Exhaust
- Garrett Gen 1 3082R turbo
- Custom exhaust manifold
- 3" downpipe
- Custom 3 1/2" aluminum exhaust
- 4" custom intake with K&N filter for the turbo
- Mac 3 port boost control solenoid
Fuel
- Precision 1650cc injectors with new O rings
- AEM -10an fuel rail
- 10an supply line
- 8an return line
- flex fuel sensor on radium split flow adapter
- Custom surge tank with 2 pumps
- Aeromotive -10an inline filter with 100 micron filter
- Aeromotive A1000 fuel pressure regulator
- All fuel lines replaced and ready for race gas VP E85 etc
- New tial BOV
Drivetrain
- Quaife ATB Limited slip differential with ring for speedometer
- Quarter Master 7.25" V-Drive clutch
- OEM release bearing
- Fidanza flywheel
- Slave cylinder extension rod
- Stainless steel line kit from master cyl to slave
- Torque Solutions shifter base, shifter cables bushings
- Shifter was rebuilt
- 1-2 billet aluminum shift fork
- 3-4 billet steel shift fork
- 1-2/3-4 chromoly shift rail selectors
- neat evo3 .618 5th gear
- FRK-5048 Competition Clutch Fork
- clutch safety switch bypass
- replaced shift shaft, axle, output and input, synchros, and seals
- Redline MT90 tranny transfer case and rear diff fluid
- 4 bolt rear end
Brakes & Wheels
- ABS deleted
- Evo 9 front calipers
- DBA 2 piece rotors
- Goodridge Stainless Steel brake lines
- Super blue racing brake fluid
- Advans RG1 18x8.5 wheels on 235/40/18
Body
- 1993 Galant headlights
- 1992 Galant rear tail lights assembly
- JDM front with working fog lights and rear bumpers
INTERIOR
- Evo 8 RECARO front seats
- Evo 8 steering wheel
ELECTRONICS
- Defi gauges oil pressure, oil temp, boost and exhaust temp
- Defi link heads up display
- AEM ECU V2
