nemovr4
Hello.
Just got my first GVR4 (835/1000). Currently not running...basically the Clutch won't disengage. Thats a problem for another post so I won't go there. Very New to the DSM world...if thats correct. its been Honda's and the hated HID'S, ebay turbos, ghetto slammed cars...Figured its time to grow up and this is the car to do it.
Small list of modifications done:
I moved the air filter forward to where the battery normally sits (and moved the battery to the trunk)
I use a lazy-Z pipe to carry the air to the turbo. The turbo is a standard 16g
BOV was replaced recently.
Standard throttle body. Port-matching and cleanup of intake manifold runners
Ported head HKS 264 Intake cam HKS 272 exhaust cam Standard valves, pistons
Port-matching to the exhaust manifold Cleanup in exhaust manifold/bypass valve
2 1/2" dia Stainless steel exhaust Large capacity catalyst
Has adjustable fuel-pressure regulator and fuel pressure gauge, wide-band O2 sensor 2 position boost pressure control (I disconnected it from the system to simplify finding air leaks)
Pictures soon..
Pictures soon..
