need help !!!!
im doing a 5 lug conversion on my vr4...can i do a 35 offset with the stock calipers?????
mooserage
Seattle, WA
Ok, first it depends on the spoke design, how wide the wheels are and other factors. Not knowing the wheel width makes the offset irrelevent (if I remember correctly). I assume you are using the stock brakes and if so I think you will be fine, but you will just have to mount one and find out really. I run 17x7.5 +38 and its really close. When in doubt though, use this wonderful guide put together by another member. click I have found though that the only way to really tell is bolt em up. Good luck /ubbthreads/images/graemlins/cool.gif
-shamus
