Molded carpet
JNR
ca
Unless something's changed, nobody makes a new carpet for these, so your only choices are a junkyard or if somebody is selling one. You can check with ACC though to verify whether they can or do make one...they have them for just about every other car out there, but for some reason not ours.
James
Port richey Florida
I know people prefer the molded carpets, but I had great luck with the rolls of carpet they sell/sold at Walmart for cars. I pulled out the whole interior, I outlined the old carpet in sections and cut the new carpet, laid down some insulation, sprayed some carpet glue stuff and worked the carpet in very slowly.
Took me some time but it looked really good when it was done.
JNR
ca
A good tip when doing carpet (and esp. molded) is to let it sit in the sun for awhile before you install it, so that it becomes more pliable and easier to work, stretch and so on.
OP - do you have holes in your carpet? If not, I'd suggest steam cleaning it (i.e. carpet cleaner you rent if you don't have one); although taking it out is best, you can do it in the car, but just be sure to let it air out good, so you don't get mildew, etc. and especially if it seeps to the underlayment.
FlyingEagle
THE Ottawa
Got some carpet from ACC carpets back in 2010.
I bought it from a Colt site member who wanted to sell it off.
This was shipped out from the ACC company in 2010, so odds are that you can still get it.
Perfect fit, you cut the holes for seats, etc, and yes it is molded.
You can buy more and in the same color, to do up the rear section if your trunk is looking to be in poor shape, but it won't be like trunk liner material.
I got the regular backing, so extra foam option, just carpet with standard backside which is pretty thin.
Food for thought, unless you want to dye it.
I had water issues around the windshield and lived in a house that was mouldy (rental at the time), so wasn't going to keep it.
NINJA EDIT - Appears that searching at ACC comes up with nothing for a 91-92 Galant, nothing available. Sorry dude. The Colt still shows in black only, with a mass backing option in case you feel like switching cars. Heck they can't be too far off from one another, but nothing worse than trying to stretch a carpet to fill out at the sills. /ubbthreads/images/graemlins/grin.gif
SmoothCustomer
Lexington, KY
Quoting transparentdsm:
here you go.
Woah $170? If that's legit I will probably be ordering it. It's hard to choose the proper color though. 7701 probably?
Barnes
Richland, WA
I was under the impression that the 2wd Galant floor pan is different than the GVR-4 floor pan, thus making the carpets incompatible. /ubbthreads/images/graemlins/dunno.gif
JNR
ca
Probably won't work then...even on my chevelle, which has similar humps on the transmission between all, there are different carpets for autos and 4-speeds, with the latter having more area to cover and hence more carpet...they are relatively close, but even so the auto will not work on the manual and the manual would be too big. The nice thing abotu those is you can put a center console to make this up (what I'll do as I am putting in a custom hump for the T-56) by cutting that area out, but if it's in the rear with the hump, you won't be able to stretch it enough and would need to be creative (as in if you're good you could splice in your own section there and nobody would know).
FlyingEagle
THE Ottawa
IF you had to, you could cut the carpet down the middle where the larger rests, assuming a FWD carpet going onto the AWD floor pan, and get someone to proper seam seal an extra section of carpet to make up the difference. You'd like never know it was sectioned in, just like household carpeting but with more pliability/moldability. Just a thought, because then you do have a completely new carpet and underlay.
