Lug nuts whats good and whats not...
onesickcrx
NY
One of my good friends needs me to order him some good lug nuts for his wheels for his CRX. I also could use a good set of lug nuts for my 17's on my Galant do to my projected power level and knowing I plan on pushing this car hard in the turns and straights or side ways /ubbthreads/images/graemlins/tongue.gif I want top of the line lug nuts. {No autozone specials}
After reading about people having issues with wheels coming off while driving because of bad lugs on this forum a couple months ago I started looking into this.
I know Brands like Volk, Buddy Club, 5Zigen, TiTek, Works, Rays and so forth are all supposed to be good, but with that said I have a hard time trusting my life to Aluminum, Magnesium and Titanium lug nuts
I am ready to make a purchase
What's everyone's opinions... /ubbthreads/images/graemlins/dunno.gif
jepherz
KC, Missouri
You wouldn't trust titanium lug nuts? Not sure I've ever even seen them.
I find it hard to believe bad lug nuts caused anybody's wheels to fall off. I'm guessing they were using the wrong style for the wheels they were running.
Barnes
Richland, WA
Quoting jepherz:
Now you have /ubbthreads/images/graemlins/cool.gif
As long as the product was properly engineered, and you use it for it's listed application, it should be fine. That is to say, if the company making the forged aluminum lug nuts says they are okay for street use, they are probably okay for street use.
The Blox Racing ones are forged 7075 aluminum. /ubbthreads/images/graemlins/ooo.gif
Barnes
Richland, WA
The aluminum ones are much cheaper but are probably still a bit lighter than steel ones.
NateCrisman
Blairstown, NJ
yeah, the AL ones are $90 and likely are the best ratio of weight/$.
I should weigh a set of 20 stock lugnuts and see what we are talking about since it's rotating weight.
H05TYL
Wgtn, NZ
Quoting Hertz:
#1, use the correct lugnuts for the wheels.
+ torque them correctly.
onesickcrx
NY
So you think the Aluminum ones are strong enough? Just seems like a steel would be so much stronger, but I cant find any steel tuner lug nuts that arent some spline style
fivestardsm
Middle, Michigan
Quoting jepherz:
I beg to differ on the junk lug issue, This was because the lugs were a set of cheap-o junk that the threads actually pulled out of. Now granted they had been used a few times, but it still would not have happened with a better quality lug > click
As for the propper lugs for the wheels though, I completely 100% agree!
onesickcrx
NY
So where did you get those lugs and what brand were they?
What lugs do all you guys run with rims since stocks wont work or fit?
onesickcrx
NY
I am ok with the steep price long as it does it's purpose have you put a bunch of miles on since buying the lug nuts?
H05TYL
Wgtn, NZ
only done a couple of thousand miles on them, Work recommends 12-15kgf/m which is ~86-108 lb/f (I only just found that now, none of them have worked loose though).
Also they are ridiculously light - come with matching locknuts too.
onesickcrx
NY
I like these Buddy Club's
Buddy Club Lugs
I also like these 5Zigen's
5Zigen
But I still feel like I have to question there strenth. I have had issue's with brand BLOX back in my Honda days so those are out.
I like Project Mu's but I think they are to big when I add the socket to fit in my wheel's
Project Mu
