Lifting the e39a vr4
MellowVR4
Milwaukee, Wi
Wondering if this has been done by anyone? I know this can be done to the early subaru's by putting the foresters springs and struts to lift it 4". Wondering if maybe the struts and springs from a mitsu expo would lift the galant?? If i could do this i would love to do it if possible. Share your input please.
I had 503 jacked up pretty high with GC coilovers a few years ago. Search my username and you should be able to find the thread. As long as you can align it afterward, there should be no issue. I think my CV angles were actually better with the car way jacked up than with it dropped down really low like I have 1051.
I don't remember. LOL
Search my username with tags like lifted, ground control, 503, jacked...
blacksheep
Urbandale, Iowa 50323
You can run GC on:
- Stock style (OEM, Sachs, etc)
- KYB GR-2
- KYB AGX
- Koni Yellows
I have run GC's on KYB AGX before. This time around, I will do it on Koni Yellows as its the best strut available for the Gvr4.
KYB AGX is an inferior strut when compared to the Koni Yellow. It cannot handle higher spring rates like the Koni. It cannot be re-built either. If you plan on running aggressive spring rates, I would suggest Koni for sure.
EDIT - I think Wop said on that thread he had on KYB AGX's /ubbthreads/images/graemlins/dunno.gif
MellowVR4
Milwaukee, Wi
I just wanna be able to raise the car safely, instead of lowering it. This would be for my ggsx not the vr4, vr4 gets lowerd /ubbthreads/images/graemlins/grin.gif
MellowVR4
Milwaukee, Wi
thanks man, will do. The only thing im realizing is that if i decide to go this route. The cost of the GC and the Full set of AGX, Will be almost the same price as just buying the BC coilovers set from BOBDOLE?? makes me think /ubbthreads/images/graemlins/uhh.gif Not sure if i could pick different spring rates on the BC, and if i would be able to raise the car with the BC the way i want to? gona do some investigating
blacksheep
Most coilovers will not allow to go higher. At the highest height, they are about 1/2" lower than stock. I don't know if longer springs will help. This may impact stroke.
EDIT - Look at ksport rallyspec - they will allow for it, I think
I used GVR4 specific Ground Controls. I don't remember the spring rates, but they were lighter than what you would get with an off-the-shelf Tein/JIC/BC or Ksport/D2/Megan coilover kit. The combination of spring free length and threaded collars allowed me to go higher than stock. I can't tell you whether or not you could do that with a different setup. At one point I had AGX's, at another point, I had GR2's.
Also, I'm not sure the kit you linked will work. I think those may be for a FWD Galant. The GVR4 setup is basically an AWD DSM kit but uses longer springs in the rear.
transparentdsm
Cherry Hill, NJ
the agx's in my car aren't that bad, i have them all set to 1 so the ride is as comfortable as possible. plus the roads around here are complete sh*t and potholes everywhere.
