knock sensor question
Dan D
Brownsburg, IN
I prefer to get at it from below. Disconnect the battery, Unplug it form behind the manifold, Pull the downpipe off and reach up past the d-side axle with a big wrench. If you drop the transfer case out of the way it is even easier. Don't overtighten when installing the new one.
Barnes
Richland, WA
+2 for under the car. Sucks to have to pull the DP, but WAAAAAY easier to get to. Plus you can actually see it. I'll also emphasize what was said above: do not over tighten the sensor.
Quoting Dan D:
This is the most important part! You will get very close to the starter connections when wrenching it!
Tre3zy
South San Francisco, CA
damn!!!! so much work for just a sensor but gotta do it /ubbthreads/images/graemlins/grin.gif thnx for the info and directions guys....
Snug, usually when I go to tighten it i use a shorter wrench so that there isn't so much leverage, tighten and maybe ad an 1/8th turn
Wizardawd
Franklin, NC
7.4 ft lbs is spec for the knock sensor. I'd try using a crows foot with a torque wrench.
Too tight and the sensor becomes too sensitive, ie...phantom knock.
Wiz
I can EASILY get to it from the passenger side above. Literally in about 1 min.
Quoting imdrax:
What tool are you using? Did you clip the wire off and just put a deep socket on it? The starter makes getting a wrench on the sensor difficult but I suppose a ratchet could work.
Why are these guys hating on the 1g sensor? AEM forum thread here.
Tre3zy
this is wat i did:
drop the downpipe
disconnect the intake mani bracket
then use a open end wrench to pull it out and put the new one in
I can also reach mine from the top of the vehicle, but i have the battery in the trunk, custom intercooler piping, and the cyclone Mani. /ubbthreads/images/graemlins/dunno.gif I can reach my arm down behind the motor and get at it with an open ended wrench.
My exhaust was already off so I hit it from the bottom with a 23mm socket after I cut the wire off and bent that tab in, then I put a little blue (med) loctite on the new one.
Quoting Wizardawd:
Hmmm, never knew that. Guess I'll be backing out my sensor and re tightening it. Unless general consensus is that I should just get a new one.
