JDM VR-4. Speed Limiter.
miller
Ireland
Any pointers on the easiest way to remove the Japanese Speed Limiter please? Its currently cutting in at the 160km/h mark.
I know on the early Evo's there is a trick to remove a link on the back of the Speedo binnacle....
MX4
New Zealand
Remove your speedo cluster. There is a screw on the back that lines up with the 180kph marking on the front of the speedo. From memory the screw has a wire running off it. Remove the screw and no more speed limiter.
miller
Ireland
Cheers, Ill give that a go at the weekend coming up.
  • Like
Reactions: MX4
misterfixit
Midlands, UK
You need a HKS SLD (Speed Limit Defencer). I'll dig out the manual and see where it plugs in. There is a speed reed switch in the clocks that feeds into the ECU and the ABS i believe It's used to help compute load I believe. The JDM cars also have a second reed switch which pulses above 65 mph or some such and that drives the Initial D sounding chime in the dash under the climate control. That one is a basic circuit very similar to a door bell.
miller
Ireland
That would be great if you could, I still haven't got around to opening the binnacle up. The Initial D chime is non existent in this one, well at least I haven't heard it yet and for sure its exceeded 65mph.
misterfixit
Midlands, UK
Here is my T-1 HKS SLD:
And here is the wiring for E39A:
The inside of the box has all the chip idents filed off.
Hope this helps.
Rich
GoCleanUrRoom
Member
Monroe, NY
Any update on if the screw solution worked? I was able to deactivate my chime with the screw trick, but also haven't gotten around to removing the limiter screw. If the SLD is definetly needed do any of you have one for sale?
miller
Ireland
I haven't got around to trying the screw trick, my GVR4 is away for paint at the moment....its a long process.
GoCleanUrRoom
Member
Monroe, NY
Nice, I'm shopping around for a paint job myself. How long is yours under the knife for? Hopefully I can go out and get some speed this week to test the limiter delete, i'll keep ya posted.
