installing balance shaft bearings...
SleepinGVR4
Danville, Pennsylvania
Yeah I got that much but how are you supposed to make sure it going in straight, Its not like you can hold it with one hand and hit it with the other. Turn the block on end?
donniekak
surprise az
I have a 32mm axle socket that works perfect. The thing is i use it backwards, with a 1/2" extension going into it from the wrong end. I do it this way because the other end is tapered, and lines the bearings up nicely.
TylerAdamson
Iowa City, Iowa
In the 5 or so BSE kits I've done I've never had issues with bearings going in crooked. I always tape the bearing to the socket I'm using and apply a liberal coat of thread locker. They go in straight every time.
