When I start my car cold, it's fine. However, if I turn it off and it is off for more than about 60 seconds, I get check engine and wicked shakes (which combined with the feeble acceleration and reek of gasoline tells me I have at least one cylinder dead). If the car remains off for several hours (at least 5), it gets cold enough that it's fine again. It doesn't seem to matter if I drive 5 miles to work or 50 miles to Denver, it's fine until I turn it off and start it warm/hot.
The problem seemed to start after I washed the engine bay prior to the recent Colorado meet. It may just be coincidence. My initial thought was that some water had gotten somewhere it oughtn't have, so I pulled the spark plug wires and blew that area out with an air compressor. Didn't fix it.
I checked the CEL code and it says injector (code 41). I disconnected the control/sensor wires (which is a PITA, btw) and blew that out with air and then applied some dielectric grease to the contacts. Didn't fix it.
I put about 3/4 can of Seafoam into the gas tank with some fresh gas to clean the injectors (or dehydrate, if that's the problem), and the rest into the crank case. Didn't fix it.
I'm gonna clean the MAF sensor soon, but other than that, I don't know what else to do besides replace injectors, and I'd rather not drop money on stock ones when I'm gonna be putting in bigger ones in the foreseeable future after I get all the upgrade stuff together. Unless the ECU is lying to me and the problem is not injectors. My roommate suggested it might also be spark plug wires...the plugs themselves are only about a year old; NGK as everyone seems to recommend for our cars.
If I do need new injectors, I might as well tough it out until I can get the big FMIC and air intake installed (currently sitting in the garage), move battery (which needs replacement anyway) and install bigger injectors. I am also supposed to be able to grab a Walbro 255 fuel pump from a dead Eclipse if/when I need it.
So ultimately, my question is twofold:
1. Any other ideas for diagnosing/fixing this problem? Anyone north of Denver got a datalogger I could use?
2. What upgrades do I need before installing bigger injectors (if I need to replace them)?
PS - Car is completely stock, has the usual 1g exhaust mani leak, otherwise in great condition.
