How to wire up a shift light?
DDM
Palatine, IL
I searched and ran into a thread that that did not help me at all. Anyone know where i wire the tach signal wire to the gvr4? Is there a pin on the ecu i should use?
DR1665
Iowa City, IA
Did you check the wire diagram in the FSM? Have a look around the Library link up at the very top of the page. I think you will find what you need if nobody drops the answer on you right away.
DDM
Palatine, IL
Let me rephrase my question. /ubbthreads/images/graemlins/smile.gif . Will the shift light worked if i wired it to the speed sensor pin on the ecu? Is the gvr4 speed sensor on pin 18 like the 1g?
