I was wondering if someone could give some tips on how to remove this there is not wnougj room to pull ot out of the car so if some of you guys can helo me on how you did thos yhat would be great thank you
Remove the two nuts for the master cyl, remove the 4 nuts on the back of the booster. Remove pin from peddle to booster rod, disconnect vac line to booster. Remove booster. That is all that is required. It's tight but It will come out.
