how do i remove headlights?
fastasleep
Christiansburg, VA
Got a boost leak at a coupler behind my driver's side headlight. It's been so long since I pulled them, I dont remember how. Help?
pull the grill unhook the hooks for the corner light. pull that out gently so you dont break it. there will be 2 i beleive 12mm bolts behind the grill and 2 behind the corner light
fastasleep
Christiansburg, VA
Yea, i figured it out. Theres actually 3 on the side of the corner light. I appreciate the response.
I just discovered I may be stripping the threads out of the intake manifold... Hopefully slightly longer bolts will hold it tight.
where at in the intake manifold where it bolts to the head? throttle body? did you strip the bolts or the threads. the manifold in aluminum i believe with steel bolts it would make more sense that the threads stripped. in that case you will have to drill the old threads out and either retap the hole with bigger bolts heli coil them or just get a new manifold(there cheap). if they stripped where it bolts to the head then its either the bolts or the threads in the head
fastasleep
Christiansburg, VA
A portion of the threading in the intake manifold (at the TB) stripped out. I believe it was caused by using replacement bolts that were too short, ie holding the TB elbow and TB onto the mani by just a few threads, which were under too much pressure, causing them to give out. I replaced them with longer bolts all around and they all stayed tight; however, it still eventually leaks under boost leak testing between the TB and elbow. I'd like to get a completely redone TB from throttlebodys.com eventually, so I'm holding out for that to replace the gasket I think.
