Help with idle searching...already checked the common..
hosmer
taunton, ma
..problems
Once the car warms up, its searching from 600-900 (average)...when it drops it *almost* dies but doesn't
checked for boost/vacuum leaks
pulled the (aftermarket civic size) radiator, and installed an OEM one
new radiator cap/hoses
grounded out for BISS adjustment, but it does nothing...still searches when plugs are grounded
now, if I unplug the (2g) MAF...it searches from 800-900...plug it back in and it goes back to the larger swing
setup right now is:
RS motor
20g/FP manifold
ETS i/c
550's
2g MAF on an FP 4" intake
running on a keydiver chip
The car did NOT used to do this, it idled fine with an SAFC hacked in by the PO (on the old setup...16g, OEM manifold, RS I/C, running on the chip and the SAFC which wasn't tuned at all). Unplug the SAFC and it searched but I assumed it was because of the mess at the ECU cannon plugs. So I completely re-did the plugs and I left the SAFC out afterwards as I was planning on going DSMLink
I'd love to solve this....car would pretty much be 100% if I did
2of9
IGH, MN
Possibly the Idle Speed Control (ISC). It's right underneath the throttlebody. Mine is also doing that.
Also when you adjust the biss you need to ground both the biss adjustment screw AND the timing connector. timing will change otherwise which does effect your idle.
hosmer
taunton, ma
The ISC was deleted before I go the car...tried grounding the idle switch to see if that help'd but of course it didn't
Hertz
Chicago, IL
So you're trying to set the BISS to get the idle to stabilize and you don't have an ISC... you're expecting what to happen? /ubbthreads/images/graemlins/dunno.gif
hosmer
taunton, ma
I'm not trying to set the BISS...I took a shot in the dark and grounded it out to see if it would help
I searched and have found NUMEROUS people who have the ISC deleted with no idle problems...I get that I have to warm the car up like I did 15 years ago with my 80-something Olds, but I don't understand why I can't get the idle to stabilize
I did NOT do this to the car...I bought it and later found the hackery under the dash...I'm just trying to save the thing, I've dumped thousands of dollars into it and hundreds of man-hours and this is the last real hurdle
Please don't assume because I just registered on this site at the beginning of this year that I'm a 17 year old kid who just got his first car and wanted something with a loud BOV to impress all my friends
hosmer
taunton, ma
Correct...but the SAFC had no settings stored (it was a version 1 if that matters)
Do they set/adjust the idle just by wiring them in (I thought the keydiver chip would be enough to run the car as-is)?
If so, can I replicate whatever it is they do without re-installing it?
boostedinaz
Scottsdale, AZ
^^^^Agreed.
If the ISC is gone your idle is going to fluctuate when a load is placed on the motor. It will also have a hard time leveling out after RPMs drop a large amount.
hosmer
taunton, ma
It's not a boost leak. The car did the exact same thing on the old setup when I unplugged the safc. I assumed the problem was in the squirrels nest of a harness at the ecu.
As I said before, the car idled fine with the safc installed...but the safc had no values stored in any of the feilds. It did at one point but lost everything after sitting for a while with no battery in the car, everything was reset to default but the car still held a solid idle.
I'm trying to figure out what the safc did to steady the idle and a way I can reproduce those results without the controller
If nothing else, I'll just reinstall the damn thing this weekend
I don't understand how the idle is surging without an ISC? The ISC is what causes idle surge by trying to adjust idle when things are out of whack, like a misadjusted BISS, or a bad FIAV, etc.
grocery_getter
Not to look down on what you already know, but...
When you take out the SAFC from the harness, did you reconnect the 2 halves of the air flow wire? When installing the SAFC, this wire has to be cut in half and then the different ends of the wire have to connected to 2 different leads from the SAFC. Basically air flow signal into the SAFC and air flow signal out of the SAFC. I have seen a few cars where they have a problem after they disconnect the SAFC because they didn't resolder the 2 halves of the wire back together again.
grocery_getter
I have installed so many ISC&FIAV delete plate on cars with stock ecu and the idle is steady. About the only caveat is that I don't do it on cars with AC because of the big load that the AC compressor put on the car when the compressor is turned on. But other than that ISC delete and FIAV delete works just fine on cars with stock ECU, even with stock chip.
Quoting turbowop:
I think you misinterpreted what I said, Andre. I realize you can get good idle when deleting the ISC and FIAV.
hosmer
taunton, ma
Quoting grocery_getter:
I dont have a CEL, so I *assume* I did?....but I'll double check
when I disconnect my MAF the surge goes from a 600-900ish swing to a 800-900 and I get a cel...plug it back in, the cel goes away and the big idle swing comes back
1qkfwd
Sun Valley, NV
Is the fiav in place stil or not? If it is then you will have to plug the plunger that bypasses air for cold idle. It wont show as a boost leak since its bypassing air from infront of the tb plate to the other side raising your idle thus making the car surge. The other thing to look at is what is your low fuel trim sitting at? If it outta wack to far one way or other it will affect your idle to the high side or low side. When it does that you are out of your target idle range that the Ecu is suppose to see. The stock target is 750 so without the isc if the car is either adding or taking away fuel its making the car idle to high or to low. When it does that the car will start surging. It can start surging if its 200-500 rpms away from its target. In order to not run the isc you have to get the idle right with the ecu. So if you get a chip with a higher target idle then you need to match that with the biss. If the screw is maxed check your fuel trims and readjust the biss as needed. Thats the joys of running the isc. If theres any kind of leaks it has a certain tolerance to keep the idle within a reasonable level to not surge. Without it you must keep everything in check on your own.
I run a Q45 on my talon there is no isc on that tb. My target idle is set at 950 so when I add fuel the rpms will go up a lil bit when they get to far away from the target it will start surging. So to cure that I would add my fuel like needed and then drop the screw down.
grocery_getter
Mark, I was agreeing with what you said. I was just posting my own experience with being able to get a steady idle without isc or fiav.
Quoting turbowop:
Ah, gotcha. /ubbthreads/images/graemlins/rofl.gif You confused me. /ubbthreads/images/graemlins/hs.gif
