FS: 16x9 4x114.3
Olson
Moreno Valley CA
300$ only 2 rims left
Real Racing rims
16x9 4x114.3
15lbs
Will clear stock rotors
One rim has a little bit of rash on it nothing you or I couldn't take care of
#3 had these for a bit
Olson
Moreno Valley CA
Wished i could have used them. When i got them from you i was excited as hell dude. Bigger and better things i guess
Olson
Moreno Valley CA
SO i think i did it right. Its a 30 offset.
the rim is 250mm wide
with a 125 centerline
a 155 back space
that gives us a 30 offset?
Correct me if im wrong on this
Probably close. Offset is from wheel centerline to mounting face based on stated wheel width, which is bead to bead (inside), whereas backspacing is from outside rim width to mounting face.
Is the 250 width you state the outside to outside of wheel measurement? Then the 30 should be accurate.
Olson
Moreno Valley CA
I have not ran these rims as stated in the first post.
Tire sizing a depended on what you want to do. use drag radials. Dot tires, race slicks. i planed on running some slicks on the car for track days but went a different direction.
So as far as i know no rub depends on what size tire you run what type spring rates you run what type of a fender you run.
What size tire i ran. I didnt run a tire but there are alot of options out there
