Front knuckle inner hub
Gtpdz
Gig Harbor, WA
When the knuckle came off the car, does the inner hub with the abs ring came out as well or it need to be pressed out?
You have to press the hub out of the knuckle to remove the abs ring. Or, you can just remove the bolts from the ring while the hub is still pressed in and cut the loose ring off.
