Evo wheel
coyotes
Seattle, WA
you can buy 4 to 5 lug bolt on adaptors, but I recommend going the right way and converting your 4 lug VR4 to 5 lug. This can be done using front wheel hubs and rotors off a talon, eagle, laser. In the rear you can do the same or swap the whole subframe which directly bolts in, although will require additional work to remove or keep your all wheel steering. Or you can swap the 1g trailing arms with the whole rear hub assembly as swapping just the hubs in rear is a much bigger pain in the ass. Good luck.
Boostdtalon
Buckley, Wa.
If you're referring to the evo wheels, than coyotes is correct. If you are referring to the steering wheel than you need to swap the hub from your steering wheel or find a 1g steering wheel to tear apart. There is a thread on here explaining exactly what to do.
white91VR4
Member
Bethlehem, PA
sorry guys I meant the steering wheel. Anyways I just wanted to know if it was the same as a 1g so thanks for that I think I found an adapter.
