DSM link, lite or full
Whats the difference in them? I want to hear it from somebody who's used them, not what the ECM tuning website says. Ive read it all...
ktmrider
Tempe, AZ
Depends on what you want to do in terms of mods.
Lite is basically for someone that would have bought a "chip" in the past. Mitsu MAF, slightly larger injectors, daily driver. Easy peasy.
Full, well it's FULL. More finite map tables, blow-thru SD, external solenoid control, etc. Bigger HP goals than the DD folks.
If you're good with ECU tuning go straight to Full. Otherwise buy Lite, learn the ropes ( ie compare maps to understand changes ), get the car running good, then shoot the moon on mods and update to Full ( nominal cost to upgrade ).
