DSM Link...Getting Started
What exactly do I need to run DSM link? I want to turn up the boost a few notches and ditch my safcII that the car is currently "tuned" on.
Thanks all.
Dark_Horse
Morrison, CO
You also will need a netbook or laptop to tune with.
Once you log with DSMlink, you will never want to go back to not knowing what your car is doing. Logging is addicting.
I have a laptop, I had HP Tuners and logged a ton on that before.
How much money am I looking at to get started on dsmlink? and how do I know if I already have a socketed ecu? my car has been around quite a bit...
Dark_Horse
Morrison, CO
Quoting rdomeck:
Should we go with the Lite or the full version? Also do you guys know if I could use a MAC to run DSMLink?
Personally, I had problems using DSMlink with my Macbook, but others have success.
Whether you want lite or the full version depends on whether you think you'll be using any of the features that are only found in the full version? click
I figure that it's only $120 difference...And in the future, who knows what features you will use. If you are going to run large injectors at any point, I'd definitely say that the full version is worth it since it gives you the ability to control dead-time for each injector.
