Different front engine brackets?
tektic
ronkonkoma, ny
Looking through my parts and noticed one power steering bracket labeled 10 and one labeled 8. Are they different?
tektic
ronkonkoma, ny
I meant the front engine bracket that in turn holds the power steering pump bracket. Ihe one with the 2 studs that the rt side L shaped engine mount bolts to. Sorry. I guess that wasn't very clear at all.
I have never noticed a number on mine. Where is it located?
I have never noticed a difference either. The bracket would not be a cast or molded part, so I see no reason for a number on them.
tektic
ronkonkoma, ny
Still wondering about this
This one is from a non turbo manual 1g. The one from my auto Galant gsx has an 8 instead of a 10.
tektic
ronkonkoma, ny
I just noticed these are a matched set. The engine that came out of my Galant has an 8 cast into the the timing bracket as well. There is a 10 cast into the dsm bracket.
Someone please look to see what number is cast on the vr4 brackets please.
I took a picture but won't upload right now. I'll try again later.
holeshotmoe
VA
VR4 stock is an "8". Here's the one directly above the pump (in a mirror). Not sure the other one you're referring to.
tektic
ronkonkoma, ny
Thank you. I was afraid of that... although hopefully this is actually the issue with the drive train noise.
Edit: ASA says they are the same... Unless I'm using it wrong. I don't know why they have two different numbers on them. Looking up that I came upon this:
Driver bracket for vr4------------Mb436505
Driver bracket for awd dsm--------MB346741
Why do I remember being told over and over again that the driver side mount was the same size?
holeshotmoe
VA
I just checked ASA for my galant and my 90 eclipse VINs
and confirmed your numbers for the L-shaped brackets.
Also confirmed your number for the cast piece. But I
checked my eclipse and it has an "8", not a "10".
Lastly, front-center bracket (under the turbo) on the
eclipse has 347 on it...but it's a 5-speed. /ubbthreads/images/graemlins/confused.gif
tektic
ronkonkoma, ny
The 347 number is for a awd eclipse front, yes.
Your awd eclipse has a 8 on it? I wonder if the 10 is from fwd only?
Are the 8 and the 10 actually discernibly dimensionally different? Some times those are just casting mold numbers.
I think the main difference is the FWD vs. AWD configurations. Due to the gearbox/transfer case the positioning and I believe even the angle are different.
tektic
ronkonkoma, ny
I'm digging through my parts bin after lunch to see if I have a set of 8s. The other one is already installed on a rebuilt block.
holeshotmoe
VA
Quoting tektic:
Yes, yes, and maybe (don't know)
tektic
ronkonkoma, ny
I have two side / timing bracket that I measured and compared. That's not actually an 8 as far as I can tell. There's 3 digit numbers on the intake side of them. One bracket says 326 the other says 327. 327 is about 8mm taller than the other.
Check the size of your pictures. Uploads are limited to 2 MB. I usually have to resize my 4 or 5 MB pictures to load here.
tektic
ronkonkoma, ny
I updated my thread. It was intact image size. The side bracket is definitely different for fwd cars. I haven't been able to discern a difference withe the front bracket.
On another note the engine mount itself is different. Someone please measure this a vr4 specific one for me .
tektic
ronkonkoma, ny
The plot thickens... my car is actually different then your cars. The driver side bracket on the automatic is slanted foward a 1/4".
tektic
ronkonkoma, ny
This is what I'm talking about .
Today I installed a Galant vr4 front roll stop mount inside the 344 bracket I already had mounted in my car. It's smaller than the dsm roll stop in many ways. As a result, the engine is no longer twisted. The bracket for the drivers side engine mount is pushed forward more so on the automatic e38a chassis than in a manual e39a. The distance between the valve cover and the rad support on a vr4 is 9-5/8" . This is the measurement I now have on the passenger side, but In order for me to get that on the drivers side I have to move this bushing loop approximately 14.5mm to the front. That's quite a way. I wonder if a bracket exist like this in other markets.
Edit: lol! I think it does exist. I linked a picture of it earlier in this same thread!
