code readers
paul j
Lone Tree, CO
What is a good scan tool to get to read the cruise control codes as suggested on an archived link? Can you turn systems off and on with most of the readers?
stevep
St. Charles, IL USA
I always read them the same way I used to read the ECU, with a 12v piezo buzzer or 12v LED. But connected to the other pin.
paul j
Lone Tree, CO
Could you expound on that Steve? Hook up, interpreting beeps or flashes, etc. Also will an ECU for a 240hp (MD165808) work on 200hp gvr4 (#1551)?
stevep
St. Charles, IL USA
If I remember correctly there are different versions of the 808 ECU. Single board and dual board. The single board can be modified to be a US spec ECU. I think there are threads here discussing what's involved.
Sorry, I fixed the link.
