Code 0042 Fuel Pump Circuit Malfunction
Brunoboy
San Bruno,CA Home of SFO
Thats what it says in Dsmlink, It will start for 2 seconds, and then die, This is all after a Fuel Pump Rewire and Ecu change. Still the same when the car is changed back to stock wiring. Anyone?
-Shane
Tre3zy
South San Francisco, CA
you sure you wired it rite? did you read the link i gave you? maybe the first time you tried rewiring it you mixed up the wires and the pump probly failed...
Chim55117
Little Canada, Minnesota, United States
This sounds dumb, but have you correctly compensated for your injectors in DSMLink? When I installed my 880's, I forgot that I had previously selected 650's, and the car would start for several seconds and then die.
Brunoboy
Quoting Tre3zy:
Link is set right, and yes I hooked it up right, I put it back to stock wiring and it as well sets off the code, -___-. I read on link forum that it means that the Ecu Pin 13 doesnt see 12v's going to the pump it will shut down. The ecu is good according to Bernard (ecu rebuilder) by looking at it, I will have to get a multimeter tomorrow.
-Shane
dsmless
tucson,az
Dude I had the same problem with 96, even tho the ecu was repaired the fuel pump circuit runs were the caps like to leak so it's a chance that the acid ate that circuit too, just run a wire from your fuse tray by the obd port to pin 13 so that it will see 12 v andnot turn off the pump it will also clear the CEL easiest fix, search my username and there's a post on this
Brunoboy
mpi fuse? yea still a complete fuse, I dont see why it would be any fuses since the car is starting, it just doesnt stay on after the code is thrown,I will run a wire to pin 13 but I need to know which wire should I run?
-Shane
Jostar
Chicago,il
I had the same Problem before in a DSM, It was the Fuel relay box under the radio next to the ecu (dsm)I believe its near the ECu in the galant...
Olson
Moreno Valley CA
I had the same thing when i did my criuse elimination. Check and make sure the injector resister pack is still there or pluged in.
Olson
Moreno Valley CA
Also its gheto and stupid to do it this way but you can if your careful. Pull your fuel rail put your injectors in there so there tight get a spare CAS or pull your cas ( witch will jack up your timing) and spin the CAS. When you spin the CAS the ecu will till the injectors to fire. If you dont get anything there you might have a bad pack .. from there i dont know
stevep
St. Charles, IL USA
Quoting brunoboy:
-Shane
I know I didn't say that and checking the link forums Dave didn't quite say that either. The ECU will throw the code but it doesn't then turn the pump off as far as I can remember. Maybe they changed the code in DSMLink but the stock code doesn't.
I don't know how anybody can tell by looking if the trace for 56 or 13 is open since it sits under the heatsink.
dsmless
tucson,az
That's what I was trying to say, the ecu needs to see a constant 12v so it can keep the pump energized, any 12 v source would of worked I said the fuse tray because you can just use a spade conector and use any open fuse slot that wayyou can also splice a on off switch as a " poormans antitheft" either way it will work also the CEL should of came off well luckman
