cheezeballs
New member
Hi, i'm new here. I need your help.
Engine:4g63na
Issue: choking on low rpm(1000-2000 rpm)
Had my tune up done. When my mechanic check the engine, timing was retarded. What we did, put it at top dead center. Since then, it would choke/misfire on low rpm, i have read few articles regarding the correct timing for 4g63. 5degrees advance, with the use of a timing gun, from TDC going to 5 to 10 degrees, choke on low rpm is much worst as i set the timing in advance but if timing is retarded, less choke.
Things i've done so far:
Change fuel filter.
Change spark plug.
Next in mind would be high tension wire. My question is, does it have something to do with the high tension wire? But why if the timing is retarded, it runs fine?
Hipe you can help me solve it.
Thanks!
Engine:4g63na
Change fuel filter.
Change spark plug.
Thanks!
