check engine light
got a check engine light put the scan tool on and getting no power from the plug.checked all fuses and they are fine what else do i look for.
thanks
Muskrat
Lexington, KY
Give it more than a couple hours.
What do you mean not getting power? Like connecting to a 5V or 12V supply? Or not getting a signal from the ECU?
The diagnostic plug doesn't supply any power, only communications. Have you tried the alternate way to read the codes:
I like using a 12 volt LED from Radio Shack.
Muskrat
Lexington, KY
^ +1. That why I asked.
If that doesn't work check the wiring for continuity.
