carriers?
Wondering were everyone got there drive shaft carriers from? Having no luck at the in town parts store.
Awesome. Ill hit them up. I hate dealing with Mitsu. I have been told one to many times " Theres no such thing as a turbo awd galant".
IMO, fill them with window weld and be done with it. But I'm sure someone will say that it's a bad idea.
Whoodoo
Binghamton, NY
If they are as bad as mine (making my car do the wub wub real bad), there isn't any harm in trying to fix it before you fork over $$$ for new ones. I'll be doing it soon... When I know I can afford new ones if I screw it up.
Adorsey
mass
JNZ or Extremepsi. They make solid bushings to replace the rubber gromet and washers to hang the propeller. Not a bad idea if you want to spend the $. (Ive seen washers welded on for 0$ so it your opinon)
You would want to do the U-joints while they are out.
Have fun with it
If you do u-joints, get the solid core, non-greaseable type. The greaseable, crossed drilled type break. I've broken two, with less than 250 whp.
