car starts without CLUTCH?
yeti
san diego california
ANY IDEAS?
maybe PREVIOUS OWNER did something
or is this normal?
since these cars are
/ubbthreads/images/graemlins/worthy.gif
Check the clutch pedal. there is a switch (plunger, press type) the clutch pedal lever presses in. Maybe its disconnected or disabled.
edit again...
My 3000gt starts without a clutch because it has remote start. If you have remote start then that is why.
edit yet again...
The galant plastic nipple that presses this clutch switch in from the level can become old, fall off, whatever.
I use a large zip thigh to replace this (just zip one in there and cut off the remainder. Why they didnt make a medal one or just kept the hole filled is beyond me.
Maybe this is what happened and the past owner disabled the switch. You cant drag race without a clutch safety switch, so keep that in mind.
You will understand what im talking about once you inspect your clutch pedal. If you dont see a white plastic part that could press the clutch switch, then its missing. Then you will only see a hole where something should go to press the clutch sensor in.
hell, maybe your switch is even missing.
here is a pic of a toyota, similar design.
Hope this helps.
As you can see the pedal has a plug on it that hits the switch. I found ours gets old and falls off. Maybe they use this to prolong the life of the plastic switch, i dont know.
But this is how the clutch start switch works. If the plug fell out and the past owner disabled the clutch switch, then you have the option of leaving it alone, or digging in there and looking at the switch and wiring.
Post some pics if you find something interesting.
yeti
I don't have a remote start
So its probably the switch your talking about
Any more tips on where to specifically look or will it be easy to notice
I'm about 2 check this in a few minutes
mpt72
ridgecrest, ca
Push the clutch down, and see where the pedal goes. Follow the metal up, and it should be right there. Also, maybe the previous owner disabled it, by unplugging it and using a wire to bypass it.
Mine does the same thing, no big deal. More than likely the previous owner removed the start switch.
mitsuturbo
Near Seattle, Washington
Why would you want to RE ENABLE This bullshit "feature"?
Every 4g63 powered car i have had.. first thing, i disable that sh*t. Saves on thrust bearing wear, saves on pain in the ass factor... it's just there because...
um..
on second thought.. you should re-enable the switch. ASAP
Quoting mitsuturbo:
um..
Whoa, thats confusing but I like it.
SouthCaliVR4
North county San Diego
Quoting mitsuturbo:
um..
ISWYDT /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/rofl.gif
Quoting mitsuturbo:
That statement didnt apply to you, RedBird. It was intended solely for "he who hath thy hairy turbo".
I didn't think it was, I like how you put it though /ubbthreads/images/graemlins/applause.gif
Adorsey
mass
I like it without it. Run out to the car on a cold morning, reach in and start her up, and run back inside. Dont even have to get in the car. /ubbthreads/images/graemlins/devil.gif
sh*t is great. IMO.
muahahahah
SouthCaliVR4
Manufacturers started putting those in to keep people from starting the car in gear. Sometimes "tasty mintz" make you forget things, like that your car is in gear. /ubbthreads/images/graemlins/blush.gif You kinda bought yourself the title of resident head, you're just gonna have to deal with these jokes now /ubbthreads/images/graemlins/hsugh.gif
SleepinGVR4
Danville, Pennsylvania
Mine does the same thing. But even when the clutch switch is connected. /ubbthreads/images/graemlins/dunno.gif I kinda need to figure out why its not working so my 2-step will work.
steve
NJ
Quoting yeti:
turbo timer is set to Ebrake
and what is the reason i should reinstall switch, just because i am retarded?
If you should have a brain fart and forget, or if someone else should try to start your car without knowing any better, you will be in for a world of hurt. If you're forgetful (ahem) it is probably best to hook it back up.
yeti
Quoting yeti:
Just tryin 2 make sure I understand
I know these jokes are far from the end /ubbthreads/images/graemlins/grin.gif
And for the switch , it gets hit buy the clutch but looks like the other side of the connecter is not plugged in and I can't see any plugs around it that match
