Can't get oil feed tube to fit properly
alik
Boston, MA
Ugh.
Yes, have both washers on banjo bolts, but, /ubbthreads/images/graemlins/dunno.gif
alik
Boston, MA
My apologies, and, thank you for the pointer.
There's a gap at the head, where the oil feed is picked up.
Both washers are on, but, it seems as if the oil line is kinked towards the driver side, so there's a gap towards the rear of the car.
As soon as I crank the engine, the leak ensues.
And, in case anyone wonders, the washers are the right fit.
What should I do? Bend the line slightly so it fits flush?
Polish
NE, IN
Stock Manifold and Turbo? or at least stock equivalent (2g/Evo)?
If not then that is your issue, different(Tubular style) manifolds will not locate it in the same spot as stock and you'll need a flexible SS line.
Otherwise I'd say your stocker got bent a bit and thus won't line up anymore.
alik
Boston, MA
Stock manifold, stock housing on Evo3 16G.
Is it possible to bend it back in order to fit?
slobra
Wilmington, De
I had the same problem when I switched to a 2g manifold. I just made my life easier and bought a braided line. Looks better and much easier to install.
alik
Boston, MA
I've got scraped knuckles, and the line is slightly bent in a different direction. Oil is running out the top. I'm pissed off.
Where the hell do I get a braided line, 'cause I'm tired of this sh*t /ubbthreads/images/graemlins/banghead.gif
Polish
NE, IN
Quoting alik:
alik
Boston, MA
Update. Couldn't get either my or my buddy's (Orlando) hard oil feed line to fit.
Ordered a flexible line (all of $24) from click (although seems like it was the only one).
