cam angle sensor???
My galant starts when engine is cold will run till I turn it off. But sputters and wont stay running if I try to start it when it is hot
Sounds like the issue I've been having lately with 503. I still haven't figured it out, even after tons of troubleshooting.
Usually, if it's the ECU coolant temp sensor, it will barely start at all, even when cold. I've logged mine and that sensor is fine.
Galantvr4559
Denver, CO
I had a similar problem with my talon long ago and and my car would idle and drive fine until it got to temp and then it would shut off and wouldnt start and spit and sputter. I told 1295 I thought it could be cam angle sensor but I am no expert still learing dsm's and gvr4's. Anyone got any thoughts???
Galantvr4559
Denver, CO
justin keyed me into something else it could be. Fuel pump. If it is going out it could cause these problems
broxma
San Antonio Tx
Do you have a wideband which would tell you if it is dying due to lean stall, which it probably is?
Id bother with the fuel system, in particular the pump and factory FPR. To give you an idea of what will happen with a faulty FPR I'll tell you what happened with my wife's car.
She has a 2001 Beetle Turbo S which I replaced the factory FPR with a 3 bar so it could run a Revo flash. The diaphragm internally wore out over the course of about two years and was shooting fuel back through the vacuum line into the intake manifold, unbeknownst to me. Up until the complete failure of the FPR, the car had trouble starting when hot. Upon total failure, the car would not run at all and died on her way to work. I has long suspected the FPR to be an issue, pulled the vacuum line off and told her to crank the car. Gas came out the vacuum nipple full pressure and soaked the engine bay.
I don't know of many FPR failures such as the one the wife had, but this was with an OEM Bosch FPR after just a few years. Certainly faulty manufacture, but still, very odd.
/brox
Ok thanks i will check the fpr out also. Does anyone think a bad alternator could be to blame,or is it safe to assume if it has the juice to crank and start it should be able to idle
Galantvr4559
Denver, CO
91galant1295 is coming over tonight so we can do some diag. I have heard everything from fuel pump to cas to coil packs, so when he gets here were gomna try to figure it out
Galantvr4559
Denver, CO
so I checked fpr and that isnt it. we still need to check out the ecu real quick before we take out old coils and plugs some coils I have up to see if its the problem. Diego had the same problem in a 1g gsx and it ended up being a bad coil pack. Since he is gonna replace the fuel pump im not gonna bother.
