boost leaks
thecannoliman121
Active member
Rhode Island
when my car is running. I have pre loaded the waste gate and the most boost I am getting out of my 16g is 5 pounds of boost. im wondering where to look for leaks. I have the tester. just looking for guidance if someone has any?
/ubbthreads/images/graemlins/banghead.gif
AnotherNewb
Orlando, FL
Throttle body, intercooler pipes and couplers, turbo outlet pipe, injector seals, intake manifold are all common places they leak. When you put your tester on it should be obvious if you're loosing that much air. Don't rule out an exhaust leak. Cracked manifold or even a cracked turbine housing, especially around the waste gate flapper.
EfiniX
portland, or
It shouldn't be too hard to find if you are only getting 5psi. my turbo (20g) was pushing 20psi and my tuner/mechanic (EHMotorsports) said it was leaking boost like a sieve from a dozen places.
BogusSVO
Pensacola, Florida
Fuel injector seals at the head is another common one. Along with the TB shaft seals.
If you do a BLT and the rad over flow bubbles, that is the FIAV seal shot.
Wrong/improper installed TB gaskets leak too.
Missing O ring on the compressor cover can be a huge leak.
