Best deal on OEM 4g63 engine gasket kit?
coyotes
Seattle, WA
Is JNZ the best price? I am looking to be a cheap ass and find it for the lowest cost.
tektic
ronkonkoma, ny
I got what I needed from Mitsubishiparts.net I got mostly evo 3 stuff though. I picked what I wanted. Didn't buy a set.
BogusSVO
Pensacola, Florida
I used mostly Engine Tech gaskets, no issues from them, They are not bad priced. But I toss the HG and use a Felpro 9627PT
But I have also used, Evergreen, Erstic, Topline from Ebay on some builds, customer supplied. I still toss the HG from all of them, along with the oil pan gasket, and use the Felpro HG.
Now IIRC, it is the Evergreen gasket set that is the most complete, including new crush washers for the oil squirters.
G
zompton
I would go all oem. It's not worth the headache to save a few bucks.
coyotes
Seattle, WA
That is my likely course of action, just wanted to hear some input.
Evan told me to go OEM so I better not make him mad.
BogusSVO
Pensacola, Florida
The big thing with any gasket, is a good clean oil free surface and proper torque on the bolts that join the parts.
Yes some gaskets are more critical than others, the head gasket being the main one, along with a decent VC, front crank and rear main seals. You can add valve stem seals to that list too.
But as far as most paper gaskets go, not enough difference to tell. If the die cut is accurate.
It is not like the the auto manufactures each have there own gasket and seal plants making gaskets for them. The car manufactures cut a deal with a gasket maker and provide the engineering plans for the gasket and seals they need and have them made to there specs.
^In other words, you can save a few bucks, but still get the same OEM quality with the Fel-Pro composite gasket. If you do a little searching around, there are people pushing them upwards of 400 HP and 30 PSI. click click
Not bad for a $30 dollar part: Fel-Pro Head Gasket. There's no benefit to running an OEM composite head gasket IMO, unless you just like to pay more money for the hell of it. There are definitely things that I would only buy OEM, but a head gasket isn't one of them. Parts like the knock sensor, thermostat, and a few others, I'd try and stick with OEM.
EHmotorsports
Beaverton
my own personal car runs other then the OEM gasket. but i have to recommend factory to cover my own. if you want to run other then OEM please do so but know I frown upon it as I cant stand behind it.
raptorWagon
Oak Harbor, WA
Mitsubishiparts.net +1! And they are local, it's the webstore for Bruce Titus Mitsubishi in Olympia. /ubbthreads/images/graemlins/grin.gif
Boostdtalon
Buckley, Wa.
/ubbthreads/images/graemlins/applause.gif I'm glad you said that Tim. I was just browsing for local places to get parts.
Vr4junkie
Some wack town in CA
I agree you don't always have to go OEM as long as you use good name brands and not cheap made in China crap you should be good ..... Felpro Head gaskets are good and cheap another thing I liked was all the ones I used were made in Japan for most Japanese vehicles I worked on.
