Bad Vibes
tektic
ronkonkoma, ny
Over 80mph, with 2 different sets of wheels, I get bad vibrations in my car. so much so that my door starts to move... Anyone have any ideas as to what I should check. The same noise or motion isn't evident at any other speeds slower.
thomcasey
Indianapolis, IN
What carrier bearing bushings are you running. I used to have a vibration/strum because I was using Torque Solution solid bushings. I swapped over to new Outlander bushings, vibration gone.
tektic
ronkonkoma, ny
I guess it could be the rear u-joint or the Lobro. Front is new and shimmed as per book.
Outlander bushings
Might you have a part number for these?
The front bolt on the control arm was loose. Good possibility that was the problem. Think my inner tie rod is worn now because of it.
