AWD KW5M33-NXPV? WTF is this thing?
No idea what this is. Just tried to put my car together, and found out that the bellhousing is WAYYY too small to fit over the flywheel.
1G 6 Bolt Engine / Stock Flywheel
The trans is AWD....
iLLeffeKt vr-4
NYC
US TEL 1G 6/90 - 2/94 -> w5m332npxv is the closest one that matches your transmission. Are you sure its NXPV and not NPXV?
iLLeffeKt vr-4
NYC
According to the transmission codes thread it looks like its from a 91-94 eclipse. Sorry I can't help you further. Try taking some pics of the transmission and the numbers on it and post them here maybe someone will know.
EMX5636
Bucks County, PA
If you are positive that you have the correct flywheel, then maybe it's an AWD tranny out of an Eagle Summit awd or something... I can run the number at work on Monday if you haven't found a definite answer by then.
Justin
